RCU Forums - View Single Post - slipper nut
Thread: slipper nut
Old 01-29-2007 | 12:40 AM
abjones413's Avatar
abjones413
Default RE: slipper nut
Yes, tightened down snug is perfect. Don't over do it. Some slip is good, but not so much that it melts the slipper discs to the spur gear or gets traction at really high RPM. Some racers like it to slip a bit and grab in the high RPMs, but I like instant power, and most other bashers do too.
Also, you do not need to take ANYTHING apart to adjust the slipper nut. Just get an average open-end 14mm wrench and stick a flathead screwdriver in the teeth to prevent the gear from turning and tighten/loosen the nut.
