RE: ultra stick 60 advice needed
I broke down and bought the ultrastick 60 / saito 100 this weekend and am gearing up to build soon.
Does anyone have any pics of their servo and battery installation (rear mounted, not stock)? I want to get an idea where to mount them. I don't want to over do it and wind up having to add lead to the nose.
I also was wondering if there is any more elegant way of connecting/disconnecting the wing servos than 4 seperate connectors. Does anyone make a connector block so you are basically plugging in one large connector rather than 4 small ones? (Hoping to cut down on the goof factor a bit, and also make my life a bit easier)
Another general question, is there any minimum storage/use temperatures for epoxy? It has finally gotten cold in NJ, and my garage/workshop is not really heated (except for the 1500W space heater that is only on when I'm working).
Dave
