RCU Forums - View Single Post - Landing gear
Thread: Landing gear
Old 04-15-2002 | 01:04 AM
FHHuber
Banned
Default Landing gear
Taildragger... with the aircraft level attitude (as if flying) the axle for the mainwheels should be approximately under the leading edge of the wing. That is a good reference to start.
Many low-wing taildraggers (such as the 4*) the mains are ahead of the leading edge by up to 1/3 the distance that the CG is behind the leading edge, and that's pushing the forward limit. (if the plane is "squirrly" on the ground, put a wedge between the dural and the fuselage and that will move the axles to the rear and help out) I wedged my 4*40's mains 1/8 inch at the front and its much nicer on the ground now.
Trike gear... the mains should never be behind the trailing edge of the wing. Usually 1/2 way to (or a bit more to the rear) between CG and the trailing edge works out correctly.
If a trike plane refuses to rotate, lengthen the nose strut 1/8 inch at a time until the problem's solved.
For most models... the nosewheel should be mounted to the firewall... further back can cause "pogo-stick" landings... where you can't prevent a small bounce from resultinng in the nose jumping higher each bounce... results in the nose getting ripped off the plane almost every landing.
