RE: loosing compression
if you ran tank after tank and DID NOT break the engine in correctly your engine will be toast in no time. and yes your clutch bell is shot( gear mesh was too tight or too loose). clutch bell's are about $15-$20. did you check to see if the head screws are tight? what temps were you running at?
