RE: Cp Pro & DD brushless Tail
Hi
Thanks for all your info Truglodite
Did I read correctly that the stock CP Pro Transmitter does not work when using a brushless dd tail with a Phoenix CC ESc??
so, heres my latest info, thought I would source parts so that when the time comes I could either go DD or just replace existing motor
Parts Needed
MOTOR GWS EDP-50Xc
whats the shaft diameter of these?
PINION ??
stock pinion is 8T .5m this .5m may be the shaft diameter or the pitch diameter??
BLADES EP 3030 and EP3020 for DD setup
ADAPTER ??
I think I need something to get the 3030 or 3020 blades to attach to the new motor for DD setup..
HEATSINK HH316
Also, noted a part number 68251 motor with pinion, this may work??? 9 tooth? motor will have to work a little harder
[link=http://www.helihobby.com/html/PICCOLO5.html]Motor and Pinion ??[/link]
You say you use a 5100kv motor with the existing tail, which motor is that/where from and was the pinion included?
Whacker
