RE: ultra stick 60 advice needed
No pictures yet, but my elevator servo is mounted 3" in front of the LE of the stabilizer. (that's the center of the servo) It is mounted as low in the fuse as possible, on the right hand side of the fuse.
The Rudder servo (pull pull setup) is mounted in the very center of the top of the fuse, and it is 8" (servo center) from the LE of the stab.
I used a short piece of CF tube for the pushrod on the stab servo, and a Dubro Pull Pull kit on the rudder servo. With a ST 90 on the nose, I still had to add 3 little stick on weights on the tail, not much at all really.
This definitely the way to go. I would do it again in a second.
Ernie
