thats all great and such but in the end its where it "feels right" that matters most to me
That's true with many things, such as throws, props, etc., but it's quicker to get where it feels right if you are starting from a close baseline. The 30% - 33% isn't a hard-and-fast "rule;" it does provide a very good starting point though and is better/quicker than arbitrarily moving the CG hoping to get it close. It also helps to remove a possible variable (CG) when trying to figure out why something is happening such as having to carry a lot of trim. Unless the plane wasn't designed within "conventional" parameters, if the CG is in this range and you are still having to carry a lot of trim, there's an issue somewhere else.
aegis: Thanks for the indepth response.. I also saved the link you posted on the other page.. thanks!
Sure. It sounds like it may help rule out a CG issue.
Using the trimming methods outlined by Peter Goldsmith takes a while, but when finished a plane flies so much better.
Dan
