RE: g90 install and setup questions?????
I just hovered a pack out.
Seems like I can set the porpotional on the 3-1 for rate mode and then when i shut down and start up in HH it works fine with the poportional left as is on the 3-1.
Maybe HH mode cancels out proportional from the 3-1 anyway?
Will do some experimenting .
Is there any reason to use the gain on the 3-1 in either setting , HH or rate on the g90?
Or should the Gain on the 3-1 just be turned all the way down?
Thanks.
