RCU Forums - View Single Post - Help ... What did I do wrong?
Old 01-30-2007 | 03:32 PM
Charlie P.'s Avatar
Charlie P.
Default RE: Help ... What did I do wrong?
Here are two more "invaluable" rubberband tricks.
Strung between pencils or chopsticks they make perfect fuselage clamps. Can be a test of dexterity (hint, do the lower ends first)
If you look close at the horizontal stabilizer you'll see a chopstick under with rubber band over. Use a pair of each to hold the control surfaces in straight alignment when zeroing control rods and servos and for setting 0ยบ or 0" on alighment gauges.
ID:	610089   Click image for larger version
