RCU Forums - View Single Post - ultra stick 60 advice needed
Old 01-30-2007 | 03:44 PM
  #84
angrycookieman
Default RE: ultra stick 60 advice needed
I can get pics later for you but basically, I just took an exacto and made very fine cuts on the bottom of the fuse until I got it cut loose. I mounted a blind nut in it and got a nylon screw with the finger knurling on it to put in it if I ever need to take it off. I then put foam behind the pushrod tubes, inserted the battery, and foamed the rest of it up. (I also put braces around the hatch for strength) Then I just taped the seams with clear tape, I will cover over it later, or make a latch system for it. Personally, it's easier than worrying about making the servo mounts right.
