RE: Radio problem - Help!
Ok, thanks, the blades are off BTW otherwise I would have a hole in the ceiling.
So I'll set the swash plate level, centre all the trims and re attach all the servo arms at 90 deg and see what happens.
I have tried all the toggle switches in all combinations and it does exactly the same regardless of toggle switch positions.
I'll report back, unless someone says stop don't do that!
