RE: Yoshioka Dash Five Pattern Ship
I am not sure about the nose gear. I think that I used a belly mount gear> You just have to look at the fuse and if there is a flat ply plate that separates the bottom of the fuel tank compartment from the bellpan area, you can mount a belly mount gear. If not you can always mount the nose gear to the firewall. If you use a mechanical gear you could try to mount the servo in the fuse and activate the retract rod using a ny rod or similar flexible device. If you did this the servo would not get fuel soaked. I would agree that you probalby woudl be better off with the 91 4S. Did you start the model a while back and are getting back to it now or is it still in the box?
Ed
