RE: ACCIPITER .120 ARF
I need advice from someone that has put an Accipiter together. The plane has no right thrust. Is this because they neglected to put it in or is it because the plane does not need any? Looking at the design of the plane I don’t think that it needs any down thrust because the engine’s thrust line is well above the wings, and if you extend the engine’s thrust line it is just slightly below the middle of the rudder. So is it possible that this design does not need right or down thrust?
