RCU Forums - View Single Post - Shuttle Plus and pitch
Old 02-06-2003 | 02:26 PM
fastawdtsi
Default Shuttle Plus and pitch
Originally posted by tail rotor
decoy
if you are learning to hover use the pitch curve to set:
high:7
hover:5-6
low:0
tail rotor
IMHO - When learning to hover, have your low pitch at +1 degree, that way, if you have to cut the throttle back real quick, it will put the bird softly on the ground. Otherwise, if you get to negitive pitch, when you cut the throttle down, it will hit the ground pretty hard.
Ernie
