Shuttle Plus and pitch
After programming the radio according to the Shuttle Plus manual I get the following pitches in Normal mode:
High Pitch: 10.5
Hovering: 5.5
Low Pitch: -5
The manual suggest the following:
High Pitch: 8-9
Hovering: 5-6
Low Pitch: -3
Are the values I got a problem?
I tried to correct these using the EPA, and I got pretty close, but then the values in the other modes were not as good. Should I change the pitch curve for the various modes instead?
High Pitch: 10.5
Hovering: 5.5
Low Pitch: -5
High Pitch: 8-9
Hovering: 5-6
Low Pitch: -3
FL
Originally posted by tail rotor
decoy
if you are learning to hover use the pitch curve to set:
high:7
hover:5-6
low:0
tail rotor
decoy
high:7
hover:5-6
low:0
tail rotor
Ernie
i have just bought a shuttle plus set up from a specialist helicopter shop,they have agreed to set the model up for free and test fly it,however i have to learn to do it myself at some point.what i want to know is what will happen if the revoloution mixing curve is not correct for the tail?[ a normal piezo rate gyro is being used] will the gyro correct for the tail swing? the radio is sanwa rd 6000 and the preset tail curve is 20% high point,0% mid point and -20% low point.will this be okay for a beginner?also the shuttle manual gives different settings for the tail pitch curve and this has confused me please help!
The Shuttle Plus manual advice you to set -30, 0, 30 with the Sanwa 6000RD for the revo mix.
I am also a beginner, and haven't tried this inflight.
