RCU Forums - View Single Post - Dubro Tru-Spin Instructions needed
Old 02-01-2007 | 11:01 AM
Timbotide
Default RE: Dubro Tru-Spin Instructions needed
Hello,
I found some sites with information about balancing props but I am unable to correctly balance the Master Airscrew composite prop that I have. I can get it to balance horizontally but it will not hold in any other position. I am not sure where to go from here. Thanks for the help, I will take a look at the site.
ORIGINAL: alan0899
G'day Mate,
I don't think I received any instructions with mine, but check out this site, the picture may help.
http://www.shopatron.com/product/pro...d=DUB499/101.0
To balance spinners, you need to set up the spinner, as you would for a prop, if it has a hole in the end of the spinner, Eg alloy type, or assembled with the rod onto the back plate.
I hope this helps, check out the pictures in the various magazines, they will show most of the options.
