ORIGINAL: tigerdude426
I will be using the method as recommended but a stupid question first
. The alligator clips clip onto the #6 screw right?
And I will be needing two sets of these pairs (2 positives, 2 negatives) one for the starter and one for the charger.
Looks simple enough even I could do it
All those connections can be gotten at Carr Hardware correct? That would be the easiest place for me to get to tomorrow.
One pair will do. Clip on the starter when you are using it. Clip on the charger when you are using that. The terminals will give you a solid place to attach to and not damage the battery by constantly fussing with it.
Carr Hardware? I have no idea what they carry. Some of it anyway I'm sure. Get what you can there and check Radio Shack later for the remainder.
