RE: A NEW KIND OF BUILD THREAD, for those of you . . .
The flight box is finally completely built, just gotta finish sanding and then apply a couple coats of wood stain.
I could not figure out how the charger was supposed to be attached to the box so I just drilled holes and attached with panhead screws and nuts.
Hope it looks OK, I think I should get the staining done in a couple days. How do the cradles look? The box satisfies me the way it came out, even if the charger was installed my own way. It is a solid hold to the box and not near anything that would sort batteries and such out while charging.
One question though: where is a good place to install the dual connector outside the box???
