RCU Forums - View Single Post - engine cut off
Old 02-01-2007 | 10:45 PM
johntammi
Default engine cut off
I mentioned in another thread that I had seen bubbles in my fuel lines before the engine cut off at 1/2 throttle. I took my tank out on a alpha trainer 40 with a evo .46 rtf. The tank has two brass fittings going thru the rubber cork. One fitting has a 3" tube with a clunk on the end, the other fitting is brass continuing at an angle towards the bottom of the tank about 1 3/4 inch long. The fuel line with clunk should go to carb and the other to exhaust, right?
It looks like I can fit some foam below the tank and possibly the sides. The tank presently sits on two balsa shelves, front and rear.
Any suggestions to help me figure this out.
Thanks for your patience.
John
