RE: idle screw setting
Here is some pictures and make sure to turn your idle trim all the way down and do all adjustments with the motor at running temp. And make a adj then drive the car around a couple of times and see where it's at. I was told to make adj like you are looking at a clock and you want to make adj in one hour adj at a time you know like from 1clock to 2 clock jsut little bit at a time. Hope it helps. Eric
