RE: NEMESIS OUTDRIVES ISSUE
I have gone thru a set on the rear(outdrive on the the trany and all three at the diff) but I have run mine for about a year..
So not bad life..I had to spend about $60 to replace them, not good!!!High wear items need to be cheaper than that..but its only money I guess I spend that on hop-ups anyway, so....
BTW Nemesis owners wait till you see the new mod I'm working on,,A hint would be, check out how smooth your brake shafts are not when useing the GST 7.7 style return spring..more on that when a couple parts arrive......
