RCU Forums - View Single Post - Matrix is finally running
Old 02-02-2007 | 07:06 PM
notch
Default RE: Matrix is finally running
Glad I could help!!! This is why I test all the products we make so that I can fully understand what you guys may be going through and give you a real answer that will help you as the consumer go in the right direction... yeah the nx-26 with the up-grade needles can still be a touchy so of a gun if that mid range is not set correctly... I run the nx-26 real fat and it still delivers great power... the motor is quite a guzzler when tuned for longevity so if your a club racer- try the TR tank... it fits right in and provides that little extra fuel that will get the bad boy to run 6 mins. Thanks for the feed back and any of you guys that need set-up advice or tips on our products check in with me... [email protected]
I have been working with some tr-.28 mods and I will report back to you guys soon on that motor..222 degrees and flying!!!!!!
