RCU Forums - View Single Post - GP Cap 232
Thread: GP Cap 232
Old 02-03-2007 | 10:47 AM
  #516
Al Lewis
Banned
Default RE: GP Cap 232
If I were building this plane again I'd agree with you 100% however, SewerDude is still suffering sticker shock from the last servo I told him to get so money is obviously an issue. Buying 6 servos he could save $120.00 just between the 3305s and the 5645s. It's always tough trying to put one of these together on a budget and I just wanted to let him know that if he goes with the 3305s he's still going to have a good plane. At 6v he'd have a transit time of .20 sec @ 60degrees and 124 oz/in of torque. Not numbers to sneer at. Spending the extra $120.00 will put him at .18 sec @ 60 degrees with 164 oz/in of torque. And it would be better but, A. Would HE notice the difference? and B. Is he going to be doing the type of hardcore 3D that would require the upgrade? Lot's of considerations there. 5985s are nearly $100.00 a piece. ($89.99) making his servos cost nearly twice as much as his plane.
SewerDude, Don't forget that with the gasser in this plane your twin rudder servos now go in the tail. You'll need a reverser unless you have a radio (9CAF) that will allow you to mix the elevators in which case you're going to need a couple of 36" extensions.
