RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 02-05-2007 | 08:57 AM
  #1112
MMallory
Default RE: Nitro models pusher Bobcat?
Landing. The plane will only hop if you have too much airspeed or if you slam it into the ground. Many jets are designed with the gear behind the cg. The key is not to land it like a sport plane. You should try to make a square on your approach and have the plane slowed down on the downwind and your final approach should be nose high (much higher than a non-jet type). Throttle will dictate your descent.
When mine touches down I am holding full up and it gently settles on the mains, rolls a bit and the nose comes down. No bent gear yet.
I hope this helps.
