RCU Forums - View Single Post - SPRING STARTER CHANGE
Old 02-05-2007 | 12:50 PM
Gaspar's Avatar
Gaspar
Default RE: SPRING STARTER CHANGE
Hello Reuben
The starter that you have is the same as used on AMT-NL engines, at least on the time that the RAM engines where made. (don't know if current AMT engines use same system now). These starters where made by a guy called Geraldo van de Heuij, that was (I think) a supplier of AMT-NL.
I don't know if Geraldo is still in bussines nor any contact data.
Regards,
Gaspar
