RCU Forums - View Single Post - damaged 4 in1 ?
Old 02-05-2007 | 04:05 PM
almaidah
Default RE: damaged 4 in1 ?
if you make an ajustment on the pot make sure you remove the battery and then reconnect it after you set the pot if you done it that way already then you might to check your tail motor. let my know if the first test works
