RCU Forums - View Single Post - A NEW KIND OF BUILD THREAD, for those of you . . .
Thread
02-05-2007 | 05:23 PM
200
sticktickler
Dec 2006
551
Des Moines IA
RE: A NEW KIND OF BUILD THREAD, for those of you . . .
Steve if I was you I think I would reinforce that end piece of the box if you plan to pull it around from the hook. You could easily pull the end piece off the box those are no load glue joints unlike a dovetail joint like a dresser drawer. They where not meant for that kind of outward pulling force which you will be applying with the handle. Beef the side section up with some 90 degree angle stock in the outer corners see drawing USE 30 min EPOXY and be neat then you should be fine.
Reply
Like
sticktickler
View Public Profile
Send a private message to sticktickler
Find More Posts by sticktickler
View iTrader Profile
