RE: Nitro models pusher Bobcat?
Dragraces:
From the pictures your prop looks to be correct.
one way to be certian is to look streight at your engine from behind the aircraft, the engine will run in a counter clockwise motion so therefore you can feel the props leading edge(if in fact this is an APC prop which looks to be)it will be countoured and smooth as with the trailing edge
will be very sharp.Hope this helps.
"Chuck"
