RCU Forums - View Single Post - Tailwheel Set Up Options
Old 02-06-2007 | 06:21 PM
Champ-RCU
My Feedback: (132)
Default RE: Tailwheel Set Up Options
A good way to actuate a tailwheel on an Ugly Stick type (Or something like the Sig Senior (ita) type rudder setups is to use a pull-pull setup. Get a nose wheel steering arm that has arms on both sides, or solder on a bracket then run your lines to the rudder servo. On a small plane like that you could use nylon fishing line, which will also afford some shock protection. If I can get a pic of one and figure out how to enter it I'll put it on later.
Mark
