RCU Forums - View Single Post - Hangar 9 80" Cap 232
Old 02-07-2003 | 06:49 AM
AnthonyI
Default H9 80' CAP
FormerCA,
I also have a FOX3.2 to put on my CAP. I havent gotton to the motor yet. I've just started on the wing. Getting ready to glur the halves together. Why did you have to alter the motor box and what did you do? I'm a little concerned with the talk of flutter. I also used 7 hinges on each aileron. Instead of the supplyied hinges I used B&B CA hinges. Do you or anyone think this will be OK or should I have used Robart hingepoints. I'm using JR8411's throughout and am rigging the rudder for pull-pull. Any other suggestions would be appreciated. Also, I plan on using 2 NiMH and 2 switches. Is this overkill?
