RCU Forums - View Single Post - Hangar 9 80" Cap 232
Old 03-27-2003 | 01:30 AM
  #59
FLY V/STOL
My Feedback: (7)
Default Hangar 9 80" Cap 232
ASAT,
I used I beleive the 1/4(?) scale robarts, I dont have the packaging any more, but if you look at the sizes available, they are the obvious choice. If you have a Robart hinge jig, they are the size that require the large jig. Anyway, I used the same size all around with no problem fitting them. I have seven in each aileron, five in each elevator, and six in the rudder, should be fairly bulletproof. Hope this helps, if you need exact specs, I can measure mine for you.
