ORIGINAL: DebianDog
Any charger is going to me limited to it max amps. For example with my 1010 I can charge at 10 AMPS but the general rule is to only charge at 1C. So for a 2200 mah pack that would be 2.2 amps. Any of the chargers mentioned should be able to do that and they all will take the exact same amount of time to do it. You can charge at more amps as fast as you like but your packs will not last long and could possibly catch fire. That is on you.
You can charge multi batteries (again up to the max AMP delivery of the charger) but I would not do it unless you have multiple balancers. (See below for example)
ok so what would the actuall time be for that batt to charge?
and if i order 2 blinky lipo balancers would that be enough to charge two batts at once?
i am not sure i understand all this...
bassiclly what i want is to be able to figure out how many batts combined with what chargers to have a constant fresh batt with the rate of flight time, e.g. flight time is 10 min, then every ten min i would need the next battery to be charged...
if i had a charger that could charge two batt at once in 20 min, or two chargers doing one batt in 20min, then i would need three batts...
hope this makes sence.
