Morris Knife
hey...its a profile...theres a chance it may not be around long......do the easy thing....go with 30" rods on the outside........try to get them and your servo arm close to the fuse with out touching the fuse.....and if you can make them run directly opposite each side thats a plus use nylon gear straps to keep them from flexing...no problemo's...
Heres a pic of my Knife right and left fuse sides...dont know if you can tell it but the rods area directly same height on both side of the fuse and then the nylon straps hold in place...
.gator
