RE: reverse polarity??
Electric brushed motors you can reverse the polarity and it will be fine. The only time is when the timing is advanced on the motor and when you reverse the polarity the timing becomes retarded. im guessing its like the bump starters they use for planes too. do you want to use it to bump start nitro trucks on the flywheel
