Go Back  RCU Forums > RC Boats > Speed - Electric
 reverse polarity?? >
reverse polarity??
Speed - Electric For all your electric boating needs.
reverse polarity??
Old 02-08-2007 | 11:17 PM
Default reverse polarity??
hey electric guys, just quick question regarding reversing the polarity of electric starter to reverse the rotation, will this burn the motor?..i have a electric starter for nitro engine proboat but want to use in truck but the rotation is reverse..thanks..
Old 02-08-2007 | 11:27 PM
YZF Desert's Avatar
Default RE: reverse polarity??
Electric brushed motors you can reverse the polarity and it will be fine. The only time is when the timing is advanced on the motor and when you reverse the polarity the timing becomes retarded. im guessing its like the bump starters they use for planes too. do you want to use it to bump start nitro trucks on the flywheel
Old 02-09-2007 | 12:18 PM
YZF Desert's Avatar
I remember seeing the thundercat using the rotostart setup so im guessing thats what kind of starter your talking about. Im not sure how that starter works if you plug a stick pack into it or what but if you pull it apart switch the motor wires and resolder you should be fine but if you just want to change the polarity were the battery plugs in im not sure about that because I dont own one of those starters.
Old 02-09-2007 | 05:58 PM
exactly the rotostart of thundercat 31, i'm thinkin of inserting a wire in the plug from the battery to the starter and reverse it.
Old 02-09-2007 | 06:05 PM
YZF Desert's Avatar
im not sure what your trying to explain, you might be alright but i dont know maybe someone else can jump in and help
Old 02-11-2007 | 06:38 PM
thanks guys for the replies,,,i made it...save big bucks no need to buy hand drill...
