RE: reverse polarity??
I remember seeing the thundercat using the rotostart setup so im guessing thats what kind of starter your talking about. Im not sure how that starter works if you plug a stick pack into it or what but if you pull it apart switch the motor wires and resolder you should be fine but if you just want to change the polarity were the battery plugs in im not sure about that because I dont own one of those starters.
