Multiple servo Q
Hi
I have an Extra 330L with a 3W70twin. The The plane can hold up to 2 servos per wing. Is it ok to use two HS5645MG per wing using a Y Harness, so I could connect two digitals to only 1 CH. I am not so sure is there is a problem in doing this. I heard something negative, not sure.
I could also use only one single HS5995 per wing or HS5955 perhaps? not sure if HS5955 will be ok or if 5995 will be too much (using also one HS5995 for rudder, two HS 5645 on elev. powered by two NIcad JR extra 1400ma, different ports and switches)
I really appreciate your recommendation.
Alex
