RCU Forums - View Single Post - Need Advice!
Thread: Need Advice!
Old 02-09-2007 | 10:12 PM
Heliko's Avatar
Heliko
Default RE: Need Advice!
The best way to go about getting the blade grips off is as Quickster said using two #1 phillips drivers that fit the screws correctly. One of the posters also mentioned that if all else fails you could use a soldering iron to heat up the screw a little bit loosening the loctite.
Personally I just used 2 new hobbico #1 phillips precision screwdrivers I bought with the heli.
Good Luck!
