RE: Which Q500 engine to buy
I talked to someone before concerning the FAI vs. 15% fuel before and was told that if you use a smaller prop and keep the rpm's above 18.5K the engines would run the same.
Did I read correctly that you can use a venturi on the Q500's for the EC?
Smitty
