RCU Forums - View Single Post - Which one would YOU choose?
Old 02-10-2007 | 02:04 PM
i live for 3D
Banned
Default RE: Which one would YOU choose?
yep, I like it alot my first one I had had a 46ax and i liked it alot until I had am midair. It had plenty of vert and pretty quick for a 3D plane. Its probably one of the easiest planes to put together. You dont even need to drill any holes! It comes with the control surfaces prehinged and motor mount preinstalled. One issue with this plane is that it is really impossible to tell if the plane is upside down or right side up. To fix that I put some red and blue triangles on the wings.
P.S. If knife edge is your favorite "trick" than just to let you know this plane cant do it it has really bad coupling towards the canopy. It hovers well, torque rolls even better, flat spin is good with a little power to keep the nose up, inverted flat spin havent tried yet, harrier a little rocky, inverted harrier much better, waterfall is so so, and blenders are real fun, and stall turns, hammer heads imelmans,cuban eights and lomcevaks(did i spell that right? are cool.
ID:	617847   Click image for larger version
