Thanks TONY!!!!!!!!
I just bought it yesturday, checking all the parts and catalogue, this thing is really easy to assemble
But, REALLY Easy
hehehe
Just wondering if it is worth putting high torque or digital servos on these huge surfaces... I am sticking to standard servos for now, but could be an option later on.
What are you using?
I am a beginner in the 3D realms, but a good flye overall
I will try to perfom all these tricks you metion and check for myself.
Do you keep the recommended travel range for the surfaces, or you have a different setting you don't mind to share?
I am planning on lots of exponential first to see how handles, and then moves from there...
Once again, thanks for your input. I feel very confident about this plane already.
I guess I will only need to seal the gaps for flutter (out of safety?!) and then carefully check the C.G.
Do you place your C.G. at the factory recommended range?
