RCU Forums - View Single Post - Edge 540T 52"
Old 02-11-2007 | 05:01 AM
nitrostaff1's Avatar
nitrostaff1
Default RE: Edge 540T 52"
The spec on the website is the spec for the plane you received. I'll ask the manufacturer to update me with a copy of the manual w/ the correct CG.
Nitro Planes
ORIGINAL: allied
Nitromodels staff, I need some info please.
I ordered, http://nitroplanes.com/edfu544052ac.html, I recieved the model and when I opened the shipping box the label said it is a 60" wingspan, .46 size. The instruction manual in the box is for a ZIVKO EDGE 540, 43.3 " wingspan .32 size.
Building is not a problem because the plane itself is flawless. However, CG settings will not be the same beween the actual kit in the box and what is listed in the manual because the actual fuselage length of the plane is not the length listed in the manual, also there are no control throw spec's in the manual. I ordered this model specifically because of the specs that were listed on your website.
The plane is perfect, no missing parts or damaged parts.
If you have any information it would be greatly appriciated.
