Edge 540T 52"
TX
Nitromodels staff, I need some info please.
I ordered, http://nitroplanes.com/edfu544052ac.html, I recieved the model and when I opened the shipping box the label said it is a 60" wingspan, .46 size. The instruction manual in the box is for a ZIVKO EDGE 540, 43.3 " wingspan .32 size.
Building is not a problem because the plane itself is flawless. However, CG settings will not be the same beween the actual kit in the box and what is listed in the manual because the actual fuselage length of the plane is not the length listed in the manual, also there are no control throw spec's in the manual. I ordered this model specifically because of the specs that were listed on your website.
The plane is perfect, no missing parts or damaged parts.
If you have any information it would be greatly appriciated.
hey, how's the NitroModels Edge 540T?? If I am correct, it's the black and orange one, right? I am looking into this plane and was wondering how an O.S. .55AX would do in that plane. Please post your a quick review in this forum for me. Overall, would you recommend it?? Thanks alot.
TX
I think the .55 will do fine in this plane, the only complaint about this bird is that I think the tail feathers are way too small, they seem to be from the .30 size plane.
Check out my thread with pics.
http://www.rcuniverse.com/forum/m_5308365/tm.htm
The spec on the website is the spec for the plane you received. I'll ask the manufacturer to update me with a copy of the manual w/ the correct CG.
Nitro Planes
Nitro Planes
ORIGINAL: allied
