RE: hooking up a engine with CDI Ignition
It ain't that easy even with a drill press, since any irregularity in the wood grain will lead the drill point astray. Even so, I don't know how I would be able to build planes without a drill press. If you don't want to get one, then you probably need a set of stand-offs, available from many sources.
