RCU Forums - View Single Post - Shuttle Plus and stabilizer bar
Old 02-07-2003 | 10:37 PM
Decoy
Default Shuttle Plus and stabilizer bar
When I view my Shuttle Plus from the front, the stabilizer bar is not exactly 90 degrees to the main shaft (and the rest of the helicopter). The stabilizer blades will not follow the same track when rotating I guess. The stabilizer bar is in line with the stabilizer control arm, so the control arm is not 90 degrees to the main shaft either.
Is this a problem?
I can't see anything I can do to fix this, as the stabilizer blade goes through the center hub.
