Shuttle Plus and stabilizer bar
When I view my Shuttle Plus from the front, the stabilizer bar is not exactly 90 degrees to the main shaft (and the rest of the helicopter). The stabilizer blades will not follow the same track when rotating I guess. The stabilizer bar is in line with the stabilizer control arm, so the control arm is not 90 degrees to the main shaft either.
Is this a problem?
I can't see anything I can do to fix this, as the stabilizer blade goes through the center hub.
Is this a problem?
Forgot the question. I didn't pay good enought attention. The bare can ofcourse move in three directions.. up and down, tilt change the attack angle of the stabilizer blades...
newbees you know
newbees you know
Do you mean while it's in flight or sitting on the bench? A little offset is normal in flight. There are lots of reasons only a physicist could understand. But suffice it to say, it's normal.
While on the bench. Haven't been in the air yet. Need help from someone to look over the machine first, but haven't found any so far.
