Need help with a warped / bent aileron.
Hi I just brought home a mini pulse xt. The left aileron is warped. It doesn't seem to be twisted. It looks like it is just bent up on the inboard end of the aileron. When I try to set it neutral ,the bent part is higher than the adjacent part where it meets the wing. I guess this is better than if it was the outboard tip.
Is there anyway to fix this without removing the aileron or covering?
I need all suggestions or tips.
