 Need help with a warped / bent aileron. >
Old 02-13-2007 | 05:18 PM
Default Need help with a warped / bent aileron.
Hi I just brought home a mini pulse xt. The left aileron is warped. It doesn't seem to be twisted. It looks like it is just bent up on the inboard end of the aileron. When I try to set it neutral ,the bent part is higher than the adjacent part where it meets the wing. I guess this is better than if it was the outboard tip.
Is there anyway to fix this without removing the aileron or covering?
I need all suggestions or tips.
Old 02-13-2007 | 07:10 PM
Default RE: Need help with a warped / bent aileron.
No way that I know of to repair it while on the plane. The upside is that horizon hobby has some of the best customer support anywhere, if you report any manufacturer defect to them I assure you they will make it right and the'll do it in a very reasonable amount of time.
