RCU Forums - View Single Post - Senior Telemaster
Old 02-13-2007 | 09:17 PM
flyingvranch
Default RE: Senior Telemaster
Forgot to add pictures I moved the firewall back several inches and ended up putting the radio in the fuselage area behind the wing for balance. I also used two servos for the elevator (one in each side) and a pull-pull for the rudder which I enlarged quite a bit. I need taller landing gear for the 18" prop which I have not done yet. The towhook I custom machined myself.
ID:	621020   Click image for larger version
ID:	621021   Click image for larger version
