pull pull on a 35% how to
Giant Scale:
I noted in your post that long slots are cut in the fueselage for the pull/pull wires to exit the fuse. How long is long enough? It seems that 2 to 3 inches must be removed for the wire to have enough clearance.
Most planes I've seen have a hole with a piece of tube that the wire goes through.
I'm asking this as I'm building a 35% Edge and also finishing up a 27% cap. On the cap, I cut long slots but didn't like the look of them so I covered them when I covered the plane.
I would prefer to just install a hole with a plastic guide tube. On the other hand does that cause binding on th pull/pull wire?
Thanks.
